H240/260 Trailer bunks
  • Thread starter George Kobernus
  • Start date
G
George Kobernus
This is related to the previous post about the side bunk height. I've read somewhere that 80 percent of the weight should be on the side bunks. It looks like my boat is 95/05 percent. Is this a problem? See this link for pics. http://pws.chartermi.net/~gkobernus/H260_Web/keel.htm
Jonathan Costello
Be careful with the tongue weight
Geroge, In moving the ladder back that far (6") you might decrease your tongue weight too much. What of you just put a block under the front of the bunk board at the cross member to raise it. Just a thought. Jonathan Costello s/v Heeling Powers
N
Nils Anderson
All the weight should be on the side bunks
The swing centerboard should only have support for itself, allowing tension on the line to be released. It should not support the hull. That's what the side bunks are for. Nils Anderson
