H23 V-berth shelves
51
Hunter H23 Barnegat NJ
Does anyone know if the glassed plywood shelved in the V-berth of an H23 have any structural function. I find them an anoyance and also want to re-use the teak wood strip and some of the ply for a patch around the chain plate. Would there be problems if they are removed? Any comments?
Thanks
RobertG
Oct 3, 2006
1,029
Hunter 29.5 Toms River
YES. They are important. the hull is very thin and that shelf is the only stiffening rib in the area. You could take the teak trim off, that won't cause any problems, and you could probably even make the shelf an inch narrower without too much of a problem, but you definitly need it.
Oct 14, 2009
51
Thanks Brian
BTW, I am from the Philly area too, near Burlington. Do you sail in the Delaware?
