It depends on your mast and step
Hi Mike:Congrats on the new boat. Depending on the year, available equioment and purchaser choice, your H23 could have one of several different masts and steps. All masts came from the factory with a winch on the starboard side.The most common masts are Kenyon and Z-Spar. The Kenyon is stiffer, heavier and a constant section all the way up, while the Z-Spar is lighter, more flexible and tapered at the top. There are also several different mast bases with matching steps. All of the bases and steps had hinges so you can raise the mast and pin it in place.On the Z-Spar mast the mainsail halyard exits over a sheave on the starboard side of the base. You pull UP on the mainsail halyard to raise the sail. It sounds goofy, but it's very effective and quite safe. You can wedge your shoulders inside the inner shroud, leaving both hands free to handle the lines. The main halyard cleats off below the winch.The jib halyard exits the starboard side of the mast above the winch. It has a cleat above the winch.Some H23's have a third halyard for a spinnaker. Like the main halyard, it exits the mast at the base. The upper end exits the mast just ABOVE the forestay. The jib halyard exits just below the forestay.The topping lift is fixed at the rear of the masthead (there's no sheave). It goes in the leftmost sheave at the end of the boom and forward to the rope clutch at the gooseneck. Pulling on the topping lift at the mast will raise the end of the boom.All the lines needed to raise, lower and reef the sails are at the mast. Some people think it's a bad idea to leave the cockpit to do these things, but IMO it's a pretty safe place to work. All the lines are on the starboard side so the boom and sails will be blow off to port when you're out of the cockpit. The boat will be on starboard tack, as well as being constrained in its ability to maneuver, so technically you will have the right of way. That being said, you shouldn't dawdle at the mast either. With a little practice you should be able to raise, lower or reef the mainsin under a minute. Like anything else, you have to work at it for a bit, but once you get the hang of it you'll find it's pretty easy. Good luck.PeterH23 "Raven"
