H23 Keel painting - Interlux's solution
Jon Bastien
Since I am painting the bottom of my boat with Micron CSC-Extra, I called the Interlux Customer Support line today to ask what they thought I should use to prepare/fair/paint the cast iron keel of the H23. Of course, since I called Interlux, all the items listed below are Interlux products. Here, step by step, is what they told me: 1. Remove all the old paint from the keel. Grind it or sandblast it down to bright metal with 36- or 80-grit paper. 2. Clean the keel using Solvent 216 to remove any residue, paint strippers, grinding dust, etc. 3. Apply one thin coat of PrimeWash 353/354 (a two part epoxy primer). Note: Primewash must be thinned 25% with Solvent 355. 4. Apply 5 coats of InterProtect 2000E to the keel. 4a. If fairing needs to be done to remove pits from rust or gouges in the keel, use the two-part fairing compound, 417A / 418B. To avoid sanding the primer away when fairing, The representative recommended putting on 3 coats of the Interprotect 2000E, then applying the fairing compound, and then the remaining 2 coats of 2000E. 5. (Assuming the rest of the hull is prepared,) Paint the bottom with 2 coats Micron CSC-Extra. Here is my cost estimate, priced through the 2000 West Marine catalog (your mileage may vary, with sales/promo's, etc.): 216 Thinner: $10.99 (1 Qt, P.324) 353/354 kit: $26.99 (1 kit, P. 324) 355 Thinner: Not available (Uh-oh...) InterProtect 2000E: $23.99 (Qt, P.321) 417a compound: $17.99 (Pint, P.324) 418b compound: $17.98 (Pint, P.324) Micron CSC paint*: $144.99 (gal, P.315) *- I can no longer get Micron CSC at my local WM store; the product has been replaced by Micron CSC Extra, at the same price. The Interlux customer support number is (800)INTRLUX (468-7589). Good luck! --Jon Bastien H23 '2 Sheets to the Wind'
Apr 19, 1999
1,670
Pearson Wanderer Titusville, Florida
Excellent post as usual, Jon B!
A lot of useful info for us wing-keelers. Now all I have to do is wait for the VC to stop working.... Peter S/V Raven
Jon Bastien
Update...
I have been reading the documantation on Interlux's web page (http://www.intelux.com), and have found that I can skip the step involving the PrimeWash- but ONLY I can apply the Interprotect 2000E within one hour of sanding the keel. I may try this, as I'm on a budget... ...Not to mention the fact that I can't seem to find the '355 thinner' required for the primewash anywhere in Key West. ;o) I found this information in their "Complete Guide to Boat Painting", which is a (rather large) document linked from their main page. Peter, Thanks for the compliment! I try to keep my posts simple and accurate... I'm planning on posting photos of this project when it's done, so everyone can see how it goes. --Jon Bastien H23 '2 Sheets to the Wind'
Ted Sonntag
H23 keel painting
If you are interested in the 355 solvent it is available through Defender Marine Outfitters for $8.95 a quart, plus shipping, plus a hazardous material shipping charge. 800-628-8225 or www.defenderUS.com Ted S
