H23 Forestay Turnbuckle Question
G
Gary Bridi
I need to replace the turnbuckle that attaches the roller furler inside the anchor locker. I cant seem to find one that meets the exact dimensions of the stock one. I don't want to be raising the masy next spring and find out that I have a turnbuckle that will not take the slack out of the forestay. I have a 1992 wing keel version. Has anyone done a replacement? Thanks Gary Bridi
Ray
Gary, Measure the turnbuckle length on the
original equipment piece. I would measure the inside of the loops at their widest point. Not at the base of these loops. Take this piece in with you if that is possible. By using the widest spread contact points then you know the absolute distance this piece of rigging offers to the entire run. You will also know the amount of length the new turnbuckle will allow you to add or subtract. Then go to Boats/US or West Marine and buy a SS turnbuckle of the same diameter (shaft wise) that offers the range of spread you need. There is a length available that will fit your needs. Ray S/V Speedy
