Summary So Far
Just 2-3 weeks ago we were sailing here in Annapolis. With the water at maybe 40 degrees, I/we (esp with my preg wife, sister, etc) cannot afford to be swimming to shore, or even waiting for it to right itself. From all the emails and posts, I'd say the one drawback to more ballast/keel is speed. There seems to be 2 ways to get more stability - speed at which the boats goes from 5 to 15 degrees heel. The first is ballast the second is wing/keel shape and weight of keel. I throw the weight of the keel into the ballast 'section' or category as the keel would have the same effect on 'heeling stability' as if it were to be made of fiberglass. The actual weight of it changes the center of gravity, whther inside or outside the boat. being outside the boat has an advantage as the CG will move to a greater distance from the CB. Weight/ballast inside the boat may not be able to move as far. The main 'problem' with the boat is heeling speed though, ie the time it takes to go from 5 to 15 degrees.As far as solutions go, one person has added ballast below the floorboards in the form of lead, formed with a mold and so on. Some have added ballast in the rear storage area. Some add bulbs, some weld new wings on.I've come to the conclusion that ballast inside the boat is the best temporary solution. I may add some books I have which were going to the library, dated stuff, maybe 2-300 lbs worth. I'll also try to get some weight under the floorboards.In the future, when the boat is out of the ice, I mean water, I'll add fiberglass wings, large area to keep boat from heeling, but small frontal area. It should go through tthe water about the same, but the area as seen by the water which has be pushed out of the way will be maybe 8-10 sq ft. Almost like a wind vane. Wind pushes the blades, they turn. When moving (only the _change_ in heel angle) or heeling rapidly, the new wings will push a lot of water, stopping the boat from heeling rapidly. It will still move to the same heel angle, just not very quickly. Like a shock absorber for heeling.Oh yea, and if you're still with me, I bought a Westsail 32, for living aboard and ocean cruising. !
