Contact Hunter
Beau, Since no one else has replyed I will hang out my neck and pass on what my owners manual says. Our boat is a 1995 H26 and our owners manual covers the same year for the H19, H23.5 and the H26, all being water ballast boats. In section 3, Sails and Rigging, #4 Ballast Tank Valve Detail, it has a diagram of the water ballast valve that I assume fits all 3 of these boats as it is the only diagram in the book. It is listed as "Ballast Tank Valve H19-A-2616". Starting from the bottom of the valve (bottom of the boat water ballast tank) you have the: 1. Bottom valve plate, 2. Bonded rubber gasket, 3. 1/2 inch rod threaded at the top that goes from the bottom of the tank to the top of the tank. Above the ballast tank in the cabin you have: 1. rubber gasket, 2. ss washer, 3. 1/2 inch wing nut, 4. and on top of the rod is a hole for a cotter pin.There is nothing inside of the tank to fall out or be dislocated in the process of changing the gasket.You should be able to remove the valve assembly and cut/scrape the old gasket off. Most auto parts stores or hardware stores will have neopreme (bad spelling) or rubber sheet pieces that you can cut to size and super glue to the lower plate to make a new gasket. Use the same thickness as the old gasket. Make sure the lower plate is clean enough to eat off (shine like a mirror) before glueing the new gasket in place. Good Luck Ray
