I have some questions pertaining to H23.5 ballast tank and hope to get some advices:
Recently while unscrewing the wing-nut of the ballast, the whole 1/2" rod came loosed - the wing-nut & rod thread is pretty rusty being a 1994 H23.5. The rod however cannot be totally taken out but can be pushed in (which means it is not total broken from the SS plate - I hope?). I checked the water level via the hole with the vent plug off and can see water level about 6" below the vent hole level.
1. If the rod is broken off from the SS plate (since it came loose), why can it be totally taken out? Is the joint between the rod and the SS plate fixed (welded)?
2. with what happened, does it mean that water from outside the hull can now come into the ballast - what shld I do?
3. I also notice that there some water at the bilge (below seats on both sides and at the V near the head) even after I drained it the week before (my H23.5 is berthed at the marina and not trailered up). Could it be because my ballast tank is leaking inside?
appreciate any advice
albert
albert
