H22 water tank capacity/purge
mike
Does anyone know how many gallons the fresh water tank holds? Mine has not been used in years and I need to recommission (found the proper technique to do so in a post from Peggy here). I am also replacing the sink drain seacock (old gate type) with a ball valve model. It's a pump faucet system so it will take a lot of work to purge/rinse/rerinse - is there an easier way, perhaps using a wet vac to the faucet hose connection? thanks for any suggestions mike
Peggie Hall/Head Mistress
How are your math skills?
Determine the volume in cubic inches...then divide by 231 to get the approximate size in gallons.
