Bill
Greetings and happy new year.I'm looking real hard at a 1983 fixed keel H22, close to making a deal. There is some question about the outboard. The boat either does not come with one or the one that comes with it is "inoperable". I have not yet chased down this issue with the current owner, but he has said that she will need a motor.So this brings up several questions...What is the recommended size and shaft length for an outboard for a H22? Does anyone have a recommendation for a good reliable motor (prefer used)?Can a new generation trolling motor (one of the monsters 24V or 36V motors with 100+ pounds thrust) push the boat around enough to be considered an alternative to an outboard? This might have significant advantages if it would work. BTW, I only intend to lake sail on Carlyle Lake near St. Louis. Not big water, but big enough to need help in dead winds and around the docks. I think it would also be a good idea to use a motor to help get back to the dock to avoid some of those pleasant midwest thunderstorms that seem to pop up in 15 minutes or so. ;-)Much thanks in advance,Bill
