leak check
Bob;It is difficult to figure out leaks but let me suggest that you close up the boat and tape all hatches/opening ports.Take a leaf blower and encase it with plastic that is taped over the hatch way. Turn it on and it will presurize the system. Take sopy water and brush the topsides with it around all fittings, hull/deck joints, etc. If you see any bubbles, then there are your leaks topside. Do you have a swing keel configuration of any sort and if so, look at the centerboard line and the bolt holding it in place. An easy way to tell if topside leakage is looking at the water level in the bilge. If it remains the same when there has been no rain, then consider it to be topsides.Crazy Dave
