I have been contemplating installing a traveler on my H216 and wanted to bounce some ideas around. First off, the traveler from Hunter is totally ugly and interfers with movement within the cockpit. One of our H216'ers has re-rigged the main and uses a rope traveler between the rear mooring cleats. This is a better solution than Hunter's but still impedes movement within the cockpit, albeit not as much as the Hunter traveler.
First question: I suspect a traveler will significantly improve upwind performance. What do y'all think?
Second question: I think one could fabricate a short traveler that would exist on the cockpit sole running between the two bench seats. I suspect you could get 12" or so of traveler movement...but, seeing as the mainsheet block is near the middle of the boom, 12" of travel at the mainsheet block would be 24" of travel at the end of the boom. This might work...perhaps not as well as the Hunter traveler, but perhaps enough to significantly improve upwind performance. What do y'all think?
