h216 Topping Lift Line Question
4
HUNTER 216 LOUISVILLE
Any thoughts about relaxing my topping lift line on my H216 to flatten the sail. It seems when I "relax" the line the boat slows. Can that be?
Oct 19, 2008
20
Hunter 216 Driveway
The topping lift plays no part in the sail trim (see Don Gillette's sail trim forum). Sail trim for the main on the H216 iis controlled by the main halyard tension, the choice of the three mast stepping positions when you step the mast, the boom vang, the main sheet, the outhaul and, if your boat is equipped with a traveler, the traveler. The topping lift is used solely to keep the boom from clunking down in the cockpit or on your head when the main is not flying. It sould be slack once the main is raised.
