L
Lamar Sumerlin
While I know this has been discussed in the archives --- spent quite a bit of time there today with a bit of luck but still lacking in info --- I would like to know what most H216 owners are doing with regard to the following quesions:The 2004 instruction manual I have for my H216 states the mast base should be bolted in the first hole of the mast base plate (i.e. the first hole one encounters as he approaches the mast base plate going into the cuddy cabin). However in the archives, I find that some are using the second hole after the first and I even found an e-mail from Glen Henderson that indicated as much. Which hole do you think is correct?My second question concerns the specified tension for the upper and lower shrouds attached to the mast of the H216 based on a Loos gauge type measurement? Does anyone have this info?Any assitance on these questions would be apppreciated.Thanks,Lamar
