H216 on a Venture Trailer
Looks like we are all set up about the same. My guess is that we all have too much tongue weight. My next couple weekends are totally tied up so I can't do anything.Here is my/our next step I think:1. Disconnect the boat from the trailer.2. Grab a scrap chunk of 4x4 or whatever 4' to 6' long. Say it is 6' just for example.3. Pile up two support platforms using bricks or whatever on each side of the trailer hitch, 3' out and perpendicular from the hitch.4. Grab the admirals bathroom scale and set it on one support platform.5. Lay the 4x4 from the scale, under the trailer hitch, and on the other support platform. Using spacers, make sure the 4x4 is reasonably level. Using little chunks of 2x4 or whatever, place these between the scale and 4x4 and, on the other support platform, under the 4x4. This makes the weight rest on two "points". A scrap piece of plywood can be placed on top of the admiral's scale and the little chunk to distribute the weight if there is concern about ruining the admiral's scale.6. Make sure the distance from the trailer hitch to each of the little chunks is the same.7. Lower the hitch until it is totally supported by the 4x4. Be careful you don't drive the scale above it's max weight. If this happens, you can shift the platforms so one is twice as far out as the other, place the scale on the long side. 8. The scale will now read 1/2 of the actual tongue weight unless you were forced to move one platform twice as far out as the other platform...in which case the scale reading will be 1/3 the actual tongue weight.9. Call the admiral out to see what you have done and compliment her on how much less she weights. Plan on sleeping outside for a few days. Spread an air mattress/sleeping bag on the bench seat in the boat.If I recall, the tongue weight should be something like 10-15% of the total weight of the boat, trailer, and other crap in the boat. (The actual percentage is somewhere in the archives...I have seen it discussed before...this needs to be researched as my memory sucks). Dry, the trailer/boat weight out at 1750. Probably using 2000 pounds is a good guess at the loaded weight not taking into account the weight of the beer. If the correct percentage is 10-15% and the platforms are equidistant from the hitch, the scale should show between 100-150 pounds. Just for drill, let's say the ideal tongue weight is 200 pounds and the scale shows 250 pounds...meaning the actual tongue weight is 500 pounds. The question now arises as to how far back we need to move the winch/mast rest pedestal back to get the proper tongue weight.Well, simple ration and proportion math will tell us. Measure the current distance (in inches) from the axle to the pedestal. Multiple this value by 200 and divide it by 500. The result is the new distance from the axle to the mast rest. Put differently,1. Measure the current distance from the axle to the pedestal.2. Multiply this by the ideal tongue weight.3. Divide by the actual tongue weight.This formula works if the tongue weight is too light also.Jeff, I noticed you use a bow strap. Instead of that, I lowered my winch down just a little so it exerts some downward pressure. The only tie down I use in on the stern. I'm not saying this is right but my boat is still on my trailer. I reduced my tie downs when I saw how my brother-in-law's 25' Grady White (yeah, I know...stinkpot...pretty nice though when tuna fishing 45 miles off shore out of the Golden Gate!).
