Jeff Prideaux
I was sailing in the ocean along Atlantic beach, NC and decided to try deploying the anchor just outside the breakers at the beach. I made sure to let out enough line to handle the ocean swells without the anchor dragging. My shore party wanted to swim out to the boat from the beach but I felt it was too rough and told them (over the walky talky) to stay put on the beach. After a while I decide to pull the anchor in and first got the motor started in idle. I figured that after I pulled the anchor up (while squatting at the bow) I would have perhaps only 30 seconds or so to get the boat moving away form shore before the prevailing wind blew me into the breakers. Well guess what, the engine died when I put it into gear. I had to make a quick decision: keep f**king with the engine or sail off the beach. I decided to trust the sail over the engine. I didn't feel I had time to raise the main sail so I un-furled the gib. Luckily, I was able to sail away from the beach under gib alone until I got enough sea-room to then raise the main and sail down the coast and back through the inlet to the sound.I was able to get the motor started later on. I discovered a small leak in the fuel hose. The motor was apparently sucking air when it tried to suck gasoline.The moral of the story, is that its nice to have an engine but sometimes when the going gets rough, you have to trust the older technology (sail power!!!).
