H170 Spinnaker
jbr
Anyone have experience with a H170 spinnaker? I've got one and flown it a few times up to 10 kts; works pretty well. Two questions: 1) the rigging diagram shows the "lazy" spinnaker sheet run between the tack line and the furled jib; when jibing, it's fairly tricky to pull the leach across this narrow slot without wrapping on the tack and/or jib. Alternative is to run it in front of the tack line but downside is possiblilty of losing the lazy sheet beneath the boat... Anybody have experience here? 2) the spinnaker is designed to be used with a "continuous" sheet; the few times I've used it it's worked fairly well but I can see the potential for line wraps/snags putting you in at risk for capsize. I know someone who pitchpoled a larger boat with a continuous jib sheet which snagged. Alternative is to cut the jib sheet and install cleats so you could more readily blow the spinnaker if in trouble. Any experience and/or input would be much appreciated.
Tommy Weaver
Gybing the chute
I always got the smoothest gybes when I sailed almost by the lee and then pulled the spinnaker over to the other side. After you get the clew (corner with the sheets tied to it) across the furled jib, you can then gybe the main as the chute completes its gybe. If you get in a hurry, as I always do when I'm racing, you will wrap the chute around the furled jib.
