H170 looker/ Moderate-air handling
Hi, Roger-Glad to hear you took a sail in the 170. Sailing main alone is a great move. I like to furl up my 170's jib when I first think I need to and just hike out on main alone. If you go with a 170 (which I would wholeheartedly recommend!), opt for reefing points in the main...they'll power her down quite a bit more yet-- making my 170 manageable in 20-25 solo or with one crew. When in a consistent blow (15+) both sails, I move up from the bench seat all the way up --sitting on the gunwale, so that I'm sitting on the top rounded edge of the hull. If I position my butt just right, the gunwale seems to fit my posterial shape (how's that for laying it out there!) and I can move in and out just a bit as headers or puffs come. Another option is one I've seen in the 170 photos section of this website-- that is to rig 3/8" line from the rudder assembly, run it foreward on the starbd. side to the mast tabernacle, then aft from the port side of the mast to the rudder assembly back on the port side. Thread that 3/8 through bigger boat 'lifeline' padding (purchaseable in 6' lengths) and use this system as a hiking strap. Also, the following link contains a retrofit optional 'heavier' 67lb. vs. 42lb. centerboard. http://www.nboat.com/hunterboats/hunter170/parts.shtml#linesOne can learn to love the 170's unique design and 'enthusiasm' in heavier air with the std. centerboard, but the retrofit option is there. I just say, Dinghies ARE sensitive by nature. You gotta love some heel-- or if not, get a tank like a Flying Scot or the like.The photo posted with this response shows a "chillin' " way to maintain neutral helm in light air--- sit on a lifejacket as padding!Full sails,Mike G.Alachua, FL
