Hi Glenn,
I have an H 376 and am in process of ordering a new mainsail.
The current sail is fully battened but it only has two reefs and is hopelessly flat below the first reef. It has the footrope in the boom groove but on the new one I shall specify it to be loose footed.
When we pull in the first reef at 18kts true it is rather overkill and the boat seems lifeless so I intend to specify three reefs on the new sail and have the first reef a little lower.
At present the luff is 49' 1"(P) and the foot is 15'3" (E) with, of course, the huge roach which distinguishes Hunter from the others.
The first reef is 9' up and the second is 19' up from the boom.
The Z-Spars boom (Z 480 section) has 4 sheaves at each end to cater for three reefs and an outhaul.
My question is:-
On my new sail how much luff do I need to specify to the sailmaker for the third reef?
I would like it to handle 40kts true as the top end because above that I tend to loose interest in the finer points of sailing and just want to get the hell out of it so would probably take the sail down altogether. Nonetheless I need the boat to still handle safely up to that windspeed.
I have done the calculations using C.A. Marchaj's several formulae but would much appreciate the advice of a boat designer.
I appreciate the 376 was probably done by Lars Bergstrom but your input would help to keep me on track - and avoid the waste of much hard earned cash!
Regards,
Don Alexander.
My question is:-
Regards,
Don Alexander.
