H-34 jib sheet size
PGIJon
Mar 3, 2012
856
Hunter 34 Punta Gorda
As part of my on going running rigging replacements.. I would like to know what size jib sheet do you use? The one that is worn out on the boat appears to have been either a 1/2 or 5/8. Is 3/8 to small for a 110? Thanks.. Jon
Nov 6, 2006
10,118
PGIJon, I went with 7/16" StaSet since I think the self tailers won't work that well with 3/8.. That has worked fine for me on the 110.
splax
Nov 12, 2012
694
Hunter 34 Portsmouth
I just replaced my jibsheet with 100' of 1/2" yacht braid. 7/16" would be OK, but 3/8" would be hard on the hands.
Dec 14, 2003
1,442
Hi Jon, attached is a sheet with all standing rigging and running rigging suggested dimensions. I agree with Splax and Kloudie that 3/8 is too small for the jaws of the winches...and the hands. I'm currently running 5/8 and it might be a bit big as it squeezes real tight into my new jaws and thus is a bit hard to undo. 1/2" or 7/16" should work great on yours if the jaws are not worn. Good luck
10,118
Nicely done, Claude ! Thanks ! I had the running rigging but not the wire rigging.. Excellent.. Merci !
Dec 14, 2003
1,442
You're welcome but I really don't deserve all the kudos. all I did was put together info gleaned here and there. Thanks anyway.
PGIJon
Mar 3, 2012
856
Thanks once again for all your great input.... I'll join in on the Kudos to Claude! I'm returning the 3/8 to WM.
Dec 2, 1999
15,184
DO NOT use Sta-set X.
The HOW site sell all grades of line that will work fine for your boat at a reasonable price.
