Well, my first year with my 81 H-30 is officially done, and am hoping to have a second year but the lake Michigan water levels may stop that..
So mean while the work on the boat continues. Somehow this boar has made it 32 years without a boom vang. And it's not like it doesn't need it! Now there are not a lot of options on rigging a vang. It almost has to attach to the mast base stand. I was planning on using a welded SS eye bolt, but looking at it this AM I think it would be pretty difficult to get a nut on the bolt as the openings are very small. Now I'm thinking about drilling and tapping a hole in the rear of the base, then screwing in the eye bolt.
Has anyone already done this, and if so do you have any tips before I start?
#2 . There doesn't appear to be any way for water to drain out once it gets inside the mast base, except to work it's way through the hole used by the wiring, then into the post area. I was thinking of having someone mill one or two grooves in the bottom plate so the water has a fighting chance to drain out. Has anyone already this? Or is there a better way ??
Thanks
Thanks
