H-26 Rudder Head - Red Rubber Glue
BrianW
Jan 7, 2005
843
Hunter 26 Guntersville Lake, (AL)
I'm replacing the red rubber gasket material on the rudder head of my H-26. I've seen several recent posts on this topic but didn't see anything on the type of glue used. Any recommendations? Thanks, BrianW
May 11, 2004
273
RAPTOR Hotfoot 20 Ghost Lake
Glue
I did mine a few years ago and faced the same problem. I ended up using " Marine Goop". Use it just like contact cement. Put it on both surfaces and leave it for about 10 min. Then use some kind of clamp to apply pressure when you put them together. This stuff is pretty handy around a boat. It does a great job of finishing rope ends when you make a cut instead of burning. Make sure it says "Marine". There's other kinds.
Jun 2, 2004
80
Catalina 30TR Polk City, Iowa
Contact Cement
That is what I used. It seemed to be what had been on there before. I can't think of any reason that it wouldn't work. It isn't water soluble and it isn't submerged, anyway.
Oct 22, 2005
93
- - Port Alice
Where to get rubber
Brian, Did you get the rubber from Hunter? I thought I read a post a few weeks ago about where to order the rubber, but can't seem to find it now.
BrianW
Jan 7, 2005
843
Thanks for Glue Info--Red Rubber Source
Thanks for the glue info all! I located red rubber sheet locally by looking in the Yellow Pages under "Gasket" classification. The owner just gave me the material without charge since it was such a small amount. Another source was in this message board. I'll try to include the link to the archive. BrianW .......................................... From Casperc: I ordered mine from Richmond Supply Here is what my order looked like; Item Code Description UM Qty Price Extended 85400048 RED RUBBER SHEET 1/8 X 36 FT 2.00 6.20 12.40 Sub Total: 12.40 Tax: 00 Shipping/Handling: 6.73 Order Total: 19.13
BrianW
Jan 7, 2005
843
Corrected Red Rubber Order Spec
Casperc corrected the amount of red rummer sheet he ordered in a later post: 2 ft of 1/8 thick x 36 inch wide of Red Rubber sheet BrianW
Jun 28, 2005
440
Hunter H33 2004 Mumford Cove,CT & Block Island
I used Contact Cement. I bought it at a West Marine store, but it's regular contact cement, nothing special.
Ron
Epoxy
Replaced the gaskets several years ago on my H26. Got the red gaskets from Hunter and used a two part waterproof epoxy to attach to metal. Has worked great without loosening.
Jun 28, 2005
440
Epoxy ?
Epoxy would hold it on, but what happens when you need to replace the rubber again? Contact cement residue is easier to remove.
