H 26 holding tank pump out fitting
Don Shirm
I own a 1995 H26 with a factory installed Groco toilet. The waste pump-out fitting is on the port side. The cap says Taiwan on the underside. The threads on the waste fitting appear to be between 1 1/8 and 1 1/4. Could this be a metric fitting? I sail on Lake Roosevelt in Washington state. All of the pump out stations require a 1 1/2 inch thread. I know there are universal fittings. These are messy. I would like the positive threaded connection. Has anyone else had this problem?
Peggie Hall/HeadMistress
1.25" is pretty standard on most boats
If you check the marine stores, it's hard to find replacement caps any more for 1.5". You don't have to settle for a neoprene "universal" fitting, though...there are threaded fittings available--SeaLand has 'em...and THINK they're shown in the WM or B/US catalog. If not, you can one (buy two...they're inexpensive, and you'll still have one if it gets dropped in the lake). Specificy 1.25", 11 TPI (threads per inch).
