h 25 rudder
  • Thread starter peachtoo@worldnet.att.net
  • Start date
Help! I need apattern for a Hunter5 25 rudder (outline). A friend of mine lost his (broke off) and a pattern is needed to build a new one. If some one is hauled apaper pattern is plenty good. He hasn't the money to buy a new one. Help appreciated.
Dave Condon
Rudder
Unless Hunter has the pattern, there are two alternatives. Find one and make one but you will need some advice. Foss Foam in Florida may well have the pattern but doubt they will give it to you but could possibly make one for you Crazy Dave
Rick
Oct 5, 2004
1,098
Hunter 420 Passage San Diego
No problem
I'll pattern my rudder for your friend. I replaced my rudder last year and made it off of a pattern. My rudder has Stainless sheet welded to rudder post sandwiched between plywood layers and West System Epoxy and fiberglass. Has seen one season of use and looked fine when hauled. I also installed a bushing on the rudder post between the rudder and the top of the boat to take the inherent slop out of the original design. My Email is sailer740@aol.com.
