Radiator Hose Fix
The radiator hose fix, described by Mr. Cherubini, has been applied to my H25. This was accomplished shortly after I purchased "Whisper" in Nov 95 due to the fact that water was trapped in the cockpit drain, froze over the winter and broke the drain pipe. This was the repair accomplished by the dealer. One thing I did to make the hose more accessible was to cut a 12X18 inch hole in the tray of the aft lazaret. Ease of accessibility also provides for ease of inspection(actually, I added the hole to facilitate replacement of the motor mount). The drain could be bigger: however, my biggest complaint with the centerline drain is when the boat is heeled over, any water in the cockpit is trapped along the side walls and does not clear until the "Whisper" levels out. It would seem that corner drains would be more advantageous than the single centerline drain; and those corner drains should probably be placed at the fore end of the cockpit. These coupled with the existing centerline drain should be more than adequate to handle most cockpit flooding situations.
