Thanks
Thanks a lot for taking the time. I am going to take a look at mine this week. Unless there was a major redesign, you will find a center cockpit drain as well as the two that you mention. The center drain is attached to a hose that passes through the berth below the cockpit and exits through a central through hull. The hose on my boat started to leak fairly bad the same day I had to leave the area. I wrapped it in duck tape, but could not get the hose off to measure it (or the fitting). There were some markings on the hose that I covered with the tape before thining. I thought I would ask around and purchase a new hose for my next trip to the marina. Thanks again!
