H-23 Kenyon mast pins
Sep 4, 2015
9
Hunter 23 Stockton, CA
I have a Kenyon mast on my H-23. It is held on the deck with two pins through the mast base and the boat. Does anyone have a Kenyon Mast? They have been discontinued and the Hunter Store doesn't stock them. Anyone got any ideas? Thanks, Bob
-na -NA Anywhere USA
Kenyon was later known as Kenyon Isomat in Charlotte, NC. It was sold to Z Spar which was a fiasco and left the country running. In a sense, it reimurged as Charleston Spar located in the building in Charlotte. It is also known as Sparcraft too. Not sure if you can locate that part there but it is a suggestio.
What I had to do in the past is get long bolts that fit the hole that were too long with the threaded end extending beyond the mast step , cutting it off and drilling a small hole in the end. If the bolt head portion was too big or in the way, I simply ground it down so it was not in the way. This was done as an alternate source.
Sep 4, 2015
9
Thanks Crazy Dave. I think I have found it at Rig-Rite. I'll know tomorrow. I may end up with your bolt fix. Much less hassle.
Thanks, Bob
