Background: The H-216 has a fixed block for the jib trim and I have no traveler, that is, it is a standard "from the factory" rig. I have moved my jib block a little and I like the way the jib flies better. I only moved the block a small number of inches forward and outboard.In a light wind, I am pointing at 45 degrees, am not pinching, and the groove feels good. I have marked my jib sheets for the "optimum" position when pointing. This position actually has me falling off a little lower then I could point and running a little hotter...better VMG as per my GPS. I normally adjust the jib first then adjust the main so it flies best with all leech telltales flowing nicely and the sail shape looks good. When I do this, the boom is not down the center of the boat...rather it is more like 15-20 degrees off center to leeward. I have tried to center the main but it stalls. If I furl the jib as a test, I can center the boom over the boat and the main flies nicely. I see pictures in my sailing mags of boats running with the boom centered and I get the impression this is what the target is, but I simply cannot do it without stalling the main. Maybe you can only center the boom when running a Genoa?So, I am happy with my pointing angle and the sails seem to fly nicely...but the boom not being centered kind of bothers me.My questions:1. Is it common to point with the boom being to leeward instead of being centered over the boat?2. Can you center the boom only if you are running a large head sail?3. Is there something I should change in my trim settings?
