I have been bothered by the number of posts about the H216 centerboard and centerboard cable. We need to solve the problem. I have had my keel bearing replaced. Also, my centerboard SS housing is bent due to miss adjusted trailer bunks and the weight of the boat basically resting on the keel.I think there are three problems:1. The weight of the keel supporting the boat while trailering due to miss adjusted trailer bunks.2. The keel not resting on the keel rest during trailering due to forgetting to lower the keel after being put on the trailer.3. Too much power on the hydraulic mechanism causing broken cables, shackles, etc.The keel supporting the boat while trailering should be a warning to the buyer and the dealer's responsibility. If I were to buy my boat new, I would check the keel positioning and make sure it can slop back and forth before I accepted delivery. My dealer is terrible and I finally had to fabricate my own rear bunk supports to get enough height to avoid the keel supporting the boat. I have an older boat and the trailers may have been upgraded since I bought mine and it may no longer be a problem. Regardless, it is something to check.I cured the keel not resting on the keel rest during trailering by fabricating a spacer that stops me from raising the keel to high. This way, my boat floats on the trailer and, as I pull it out of the water, the keel weight automatically rests on the keel rest as the boat sinks down onto the trailer. I placed the spacer around the hydraulic rod between the cylinder and the end cap of the rod where the cable is attached. My spacer is a "U" shaped thingy with a screw along the top of the "U".I have not cured the "raising it too much" problem other than yelling at my crew. I now ask the crew to pull the cover off and watch the mechanism and "stop when it gets here". I am *AMAZED* how totally powerful the hydraulic cylinder is! I have actually made three spacers as per the prior paragraph, two out of sea board and one out of oak. The first sea board one simply disappeared on it's first use. The second "survived" one use. My crew cranked the hydraulics until they felt back pressure (without ripping off the centerboard housing and watching). I found it broken off and mangled jammed down next to the keel. It had been squished to about 1/2 its original width before it stripped the screw and popped off. My oak one ended up being squished quite thoroughly after its first use. Do you realize how much pressure it takes to squish a 3/4" chunk of oak down to 1/2"!!!! Fortunately I have not broken a cable or shackle but I am convinced my cable is longer than it originally was and/or I have worn out a second keel bearing.I have no solution to this problem. What I really think is needed is an adjustable bypass valve on the hydraulics that limits the "up" travel of the keel. Any suggestions would be greatly appreciated.
