Peggie:I've studied your book, this web site, pulled my vent screen, and ensured the vent is clear. Our 2004 vintage compact manual Jabsco toilet is still giving us fits. It seems to work fine during wet mode, but gurgles during dry pump without much efficiency. And I'm also hearing the intake loop vent wheeze some during the dry mode, which I presume shouldn't occur (this is the only vented loop in the system). The toilet continues to gurgle slightly on its own in the dry mode when not being operated (with the intake thru-hull open). I removed the pump housing top and inspected the rubber gasket/valve and mode lever arrangement, which appeared to be ok. But I'm still wondering if there is some blow-by in this area. Any thoughts would be greatly appreciated. Replacement is on our list, but we'd like to make it through the season first. Thanks Peggie!
