Gulfstar 39 Sailmaster Questions
Mar 8, 2011
296
Ranger 33 Norfolk
So, I'm still looking for another liveaboard. While down in NC, I had the broker show me a GS39 while I was down there looking at a Prairie 36. Both are nice boats with potential, but the GS is the one filling my heads with day dreams of cruising into the sunset :doh:
Anyways, I'm hear for knowledge and insight on the boat in question. Performance wise, I would expect it to be similar to my Ranger 33. . .both aren't particularly beamy for the length, a little light on the displacement side, lots of sail area, and fin keeled. Out board shrouds on the GS39 probably means it can't point as high, but I don't race so. . .tiny keel sumps, etc. . .
The layout is amazing, and the big attraction. That it should be sailable in our light air is also a perk.
Questions:
-5000+ hours on the a perkins 4-108 v-drive. Engine has been painted recently, bilge as far as I could see is clean. Would those be considered high engine hours? In the Trawler world in which I've been hanging out, those wouldn't be particularly scary. . .How long do the transmissions last?
-There is a soft spot on the coach roof by a hatch. The core is 3/4" (i think) balsa (end grain). Only have dealt with plywood cores on my R33. How quickly does water migrate with balsa?
-The base of the mast step (keel stepped) is corroded. I haven't been able to find anything online about this for this particular boat. When I was looking at Pearson 365 it was a common issue with a couple common fixes. Would something similar apply here?
-It looks like it has the original Groco cone type sea cocks. I was afraid to work them too hard. They look rebuildable though?
-Rigging looks to be a mix of original and newer. None of the lower swages are rusting/cracked. There are a couple shrouds with stay-locs. I'm assuming the owner is/was replacing only what looked bad as required?
It had been raining off and on for days before, and during my initial inspection and surprisingly it was dry inside with no window leaks. I was shocked. I saw no evidence of leaks at the chain plates (of those I could see). If anyone has advice, opinions, comments I'd love to hear them! If I make a second trip down for a thorough inspection, anything in particular I should look out for?
Thanks!
Dec 19, 2015
8
Bristol 38' St Augustine
Hi Coll Beans,
I'm also have recently taken an interest in the Gulfstar 39 Sailmaster. I originally had my heart set on a Bristol 38 until I came across a Gulfstar. I am also interested to hear the replies to the questions/comment you put forward so will be following your thread with interest!
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
We lived aboard a 1981 GS 44 cc ketch for 10 yrs and cruised PNW waters. The backing plate under the forestay deck attach was corroded pretty well and covered in rust. It was also inside the anchor locker. I was starting to replace when someone else came along and wanted the boat worse than we did...
I think there is a Gulfstar for sail here in Greenport. I'm not sure of the length. Owners are getting quite elderly. When I return I get more details. He is a retired engineer and is proud of his upkeep. His wife let me know they are "ready".
Dec 19, 2015
8
Cool Beans, if you post a thread on Cruisersforum I'll follow it with you, I'm already a member, it's a good site. I'm planning to look at a Gulfstar 39 in a coulpe of weeks time, I'll let you know how I get on.
May 11, 2005
3,431
Seidelman S37 Slidell, La.
I have no knowledge of the GS 39, but have some with larger ones. Mostly ketch rigged.
Basic impressions: Super strong. Comfortable. Sail well other than upwind. Not very fast, and they don't point well.
I have found out that the Gulfstar for sale here is the 37 - not the 39 Sailmaster. Let me know if you want more info.
