Guest Battery Charger Replacement
H
Helen Pshedesky
Battery charger fried! Guest no longer makes the original equipment. 3 Stage 30 Amp 3 bank was the original. Anyone have to replace their charger and with what? Helen
Dec 2, 1999
15,184
Xantrex
Helen: Go with a Xantrex/Statpower 40+. Good charger that do their job. Never heard much good about the Guest units.
Pete
newmar
I replaced my burnt out charger with a Newmar 40amp "smart" charger.Only two years old but no problems.
Bernie Soostmeyer
I replaced the Guest Charger with a Statpower Truecharge 40+ on our Hunter 380 last year. Seems to work fine but is noisy when ambient temperature is high because of internal fan. Of course this is only a problem when connected to shore power. Also, as per manufacturers spec, the unit must be mounted vertically which may present a problem.
