Equalization Bus
Casey might be referring to an EQUALIZATION BUS*:* A metal strap inside the boat substantially parallel to the exterior lightning ground plate, and connected to the lightning ground plate at each end.An equalization bus, on the inside of the boat, paralleling the grounding strip on the outside of the boat, may be used as the lightning ground conductor. ABYC encourages use of two bolts at each end of the strip, extending between the external ground strip** and the internal equalization bus, Secondary lightning conductors can be connected to the equalization bus.** The ABYC suggests the use of a grounding strip, rather than a plate. The ABYC rule states: A grounding strip shall have a minimum thickness of 3/ 16 inch (5 mm), and a minimum width of 3/4 inch (19 mm). A strip approximately one inch (25 mm) wide and 12 feet long (3.7 m) has nearly six times the amount of edge area exposed to the water, which will improve the dissipation of charges. The grounding strip, if used, shall extend from a point directly below the lightning protection mast, toward the aft end of the boat, where a direct connection can be made to the boat’s engine. I agree that the Stan Honey “Grounding, Bonding ...” article is an excellent presentation.See also NFPA 780 “Lightning Protection” at:http://bluegrasslightning.com/780-00-PDF.pdf
