Grounding Plate
Julia
Dec 19, 2007
5
- - Southhampton. UK
removehtml]I have purchased a catalins 30 and can't find a grounding plate. Could another owner point me in the right direction please. Julia.Error: Error: expected [/URL], but found [/removehtml] instead[/removehtml]
Nov 12, 2006
256
Catalina 36 Bainbridge Island
Grounded Catalinas?
There is no grounding plate. Grounding plates are not standard equipment on boats. If you sail in an area that is high in lightning strikes, it is probably a good idea to add one.
Julia
Dec 19, 2007
5
Mick, many thanks, my previous boat had one but not a difficult fix. Julia
Jul 1, 2004
398
Catalina 30 Atlanta GA
No Grounding Plate
First, the mast of the 30 is deck mounted. On vessels with masts mounted through the deck, you might see grounding wires form the base of the mast to the keel bolts but not in the case of the 30. If you follow the upper and lower shroud support plates into the cabin these are tied into the teak bulkheads. The forstay goes to a support bracket and into fiberglass as with the aftstay. I have not seen anything grounded to the keelbolts on my model (1988 Mark II). I would not worry too much about it Julia. Their is much written on grounding, lightening protection on vessels and measures you can take on the water. I am no expert on the subject, but I have been caught in dozens of lightening storms and have yet to experience even a close strike. Bob
Julia
Dec 19, 2007
5
Grounding Plate.
Hi Bob, I was thinking more of grouding the eletrical system than lightening although the previous owner did have a strike, many Thanks, Julia.
