grounded vessel
May 25, 2012
4,338
when freeing a grounded sailing vessel i prefer to tow from their spinnaker halyard.
ever tried that?
May 1, 2011
5,561
Pearson 37 Lusby MD
That lets you heel the grounded vessel so it can be powered off whatever it is stuck on. Used a RHIB to heel a Navy 44 that had run aground leaving St Michaels MD enroute to Annapolis.
Gunni
Mar 16, 2010
5,937
Never had an imposed heel alone free a sailboat. Heel + kedging anchor gets the job done. And you have to be heading toward deep water too! :)
Likes: BrianRobin
Jun 10, 2017
174
Catalina 1980 Catalina 30 Mk II John's Pass / Tampa Bay
I AGREE WITH GUNNI,
If IN FLAT WATER & AGROUND ON SOFT BOTTOM, USING THE MAIN HALYARD TO TILT THE BOAT SLIGHTLY SOMEWHAT, WILL PITCH THE KEEL OFF & HOPEFULLY ALLOW FOR AN EASY FLOAT-OFF.
Sorry for the caps, I forgot TO click THEM OFF......
May 25, 2012
4,338
i have towed , maybe 10 times, sailboats, off the hard, with no other lines or engine involved, using just the spinnaker halyard attached to another long line such as my anchor rode. has always gone well. scuffing sure, nothing more
May 25, 2012
4,338
maybe i have more guts than brains.
..... and i always did the towing
Aug 1, 2011
3,972
wing keels tend to dig in if you induce heel. I've heard that and never intend to find out if it's true.
Likes: BrianRobin
DArcy
Feb 11, 2017
1,788
Islander Freeport 36 Ottawa
I pulled the Candian deputy Prime Minister off the rocks many years ago using a halyard to heel the boat. Usually the tow boat just provides heeling moment and the stricken vessel powers off.
Likes: jon hansen
Gunni
Mar 16, 2010
5,937
I was always a bit hesitant to use the engine in lieu of a kedge. The thought of pulling a wad of mud into my heat exchanger gives me pause. Don't ask for a tow from a powerboater unless they look like they know how to operate a boat, the crabbers just flip you the bird. Sailboats don't have enough power to tow...so it off to set the kedge, then if needed a halyard tied to the dink. Then we start the show and the crowd of lookie-lou boaters assemble. I refer to the Catalina's as "Chesapeake Two-bottom plows", think you have to have spent some time down on the farm to get that ;)
