I was the lucky sole that had to replace the mast and the rigging as the mast broke in 1/2 at the spreaders. Finally got it back in February and doing some small maintenance things when I spotted a problem. There is what appears to be a ground wire in the cabin v berth that is on the ceiling and obviously was attached to a bolt that ran from the mast step to a keel bolt. It appears that the wire was put in during when the boat was built. The wire runs between the carpet and the fiberglass. Is this ground grounding the mast to the keel, or is it for the lights?
:dance:
