To clarify Patrick's point...
We tend to use the term 'ground' generically, but Patrick's pointing out that there are two separate, distinct kinds of 'ground'. One is the -12V ground to which our rigs, tanks, engine etc. are tied to. (The 'green wire' ground...).Ron's subject is about the other kind of ground, the RF ground plane, which is essentially half of an antenna system for SSB radios. It is very common for folks to tie these two 'grounds' together, not only because they might believe them to be the same thing, but also because the thinking is that using the -12V ground will automatically tie together all those hunks of metal, thereby physically enlarging and therefore improving the RF ground plane.One consequence of this is that the 12V electrical system is invited into the RF ground plane, and vice versa. Examples of this are when one keys the mike and watches all the DC panel LEDs light up (RF getting into the 12V system) or the 12V reefer motor kicking on & distorting the transmitted SSB signal (DC hash intruding on the SSB).ABYC standards have the AC and DC grounds connected for safety reasons (altho' this is still debated widely), and this can further affect things if the two 'grounds' are confused. However, it sounds to me like Patrick's damage was caused by an AC wiring error well beyond an incorrect SSB installation, since the SSB on his neighbor's boat was probably unpowered 99+% of the time.Patrick, have you subsequently installed a galvanic isolator? They're not much money (maybe 1% of your repair bill), easily installed and good insurance.Jack
