Groco toilet won't pick up raw water
Apr 28, 2005
271
Oday 302 Lake Perry, KS
Have an older model Groco toilet. It will dry flush just fine - but won't pull raw water into the bowl. (Yep, I checked to make sure the thru-hull was open!)
Is this likely a simple joker valve replacement? Assume there's a rebuild kit...but is it worth it to put more money into a Groco toilet that's at least 10 years old? (see below)
Oh...the toilet seat also broke yesterday - the plastic hinge simply fell apart and disintegrated. Is this thing worth fixing - or should I bit the bullet and get a Raritan (PHII model I think is the one that Peggie likes?) and swap out the old Groco for a better model?
Can't think of a more fun job than swapping out a toilet in the Kansas heat this summer!
Thanks for your help on this.
RoyS
Jun 3, 2012
1,742
Possibly a jellyfish in the raw water pickup. You should feel resistance at the pump if that line is blocked. Reverse flush the line with a hose from the dock. Did this a few days ago with a similar toilet.
Apr 28, 2005
271
No resistance at the pump - goes up and down smoothly. Just won't bring in any fresh water. Thanks.
While it is unlikely that a jelly fish lives in Kansas, it is possible that something else is plugging the seacock.
Close the seacock, remove the hose, and then open the seacock. If you don't get a stream of water then you know it is plugged. Stick something down it to clear the clog. If you do get a stream of water, then you know the problem is in the pump.
Money spent on a rebuild kit and new seat is probably better spent on a new head.
Likes: RoyS
Dec 2, 1997
8,915
- - LIttle Rock
According to Groco, the average lifespan for the HF is 9-11 years, so if yours is older than that it's time to replace it. The Raritan PHII has been the top rated manual toilet for 30 years...keep it lubricated, replace the joker valve annually and put a rebuild kit in it every 5-6 years and it'll easily last 20+ years.
The Raritan PH SuperFlush Raritan PH SuperFlush is the current version of the PHII...uses the PHII pump, but the base has been redesigned to match the mounting bolt pattern on most other manual toilets. Available as a complete toilet or as "conversion" (everything but the bowl, seat and lid). I couldn't find it in the sbo.com store, but I'm sure Dave can get it.
--Peggie
"If you can't explain it to a six year old, you don't completely understand it yourself." --Albert Einstein
Apr 28, 2005
271
Thanks Peggy. If The Authority says it's time to get a new one...it's time to get a new one. I'll get one of the new Raritan Superflush models and hope the installation is no more than a 2-beer job!
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
@kloudie, I am in your camp. While the Raritan is superb, that Groco could be fixed for less than any other alternative. Only thing, is that seat the right size? It might be a compact, marine bowl.
Likes: BigEasy
Sailm8
Feb 21, 2008
1,750
Hunter 29.5 Punta Gorda
We called our old head "John Wayne" 'cuz it wouldn't take crap from anybody. Took Peggies advise and ordered a Raritan through the SBO store. Never have had a problem since.
Jun 21, 2004
2,771
Beneteau 343 Slidell, LA
Raritans should last longer, they are over twice the cost of competitors. Guess the old adage, "you get what you pay for" applies in this case. If I lived aboard, it would be worth the expense; however, for casual use, my el cheapo Jabsco works just fine at 10 years.
Jan 27, 2008
3,086
ODay 35 Beaufort, NC
Did you rotate the lever to the raw water flush position ? If you leave the lever in dry bowl setting for extended time it sticks in that position. Always flip it back after you pump the bowl dry!
Dec 2, 1997
8,915
- - LIttle Rock
Your toilet must be a Jabsco...and it's only necessary to leave it in the wet position during winter and other EXTENDED layups. Leaving it in wet position can sink your boat if there's no vented loop in the intake. See the drawing on the firsst page that shows where to install it. Jabsco manual toilet short instructions
--Peggie
Jan 27, 2008
3,086
No Peggie it's a Groco. The trick to not sinking the boat is to shut the seacock when unattended. The dry bowl lever holds the flapper shut and if I remember correctly the plastic bonds itself to the lever if left for a lengthy time like weeks. It's been several years since this happened but I always leave it in wet position where the lever is not stressing anything. If the head is used regularly probably not an issue.
Jan 27, 2008
3,086
No need to replace the whole head. You can buy a replacement pump assembly. That's what wears out. The bowl and base should be fine.
MitchM
Jan 20, 2005
1,031
Raritan requires you to "replace the joker valve annually and put a rebuild kit in it every 5-6 years and it'll easily last 20+ years..." ! No thanks! my par jabsco manual head needs a rebuild about every 10 years at a very reasonable cost. you can tell when you need to replace parts because seawater starts gradually coming in even though it's set to 'dry bowl.' and par jabsco has human beings who anser the t ech suppport phone and give detailed very good advice (--most recently , last week --on how to rebuild my 1978 Par Jabsco diaphragm freshwater and bilge pumps....)
Likes: jviss
