Greetings! New Owner, Beam Question
Oct 30, 2019
2
My name is Aaron, I am the proud owner of Mariah, formerly owned by Mr. Gilchriest of this list. I've been sailing her out of Nabbs Creek on the Chesapeake Bay for the past few weeks, having a great time.
I have questions about replacing the mast support beam. I've done this before on other boats where the rafter was glassed in and made of 15 layers of 1/4" marine ply laminated together. But on the Vega, it seems to be three layers of 3/4" mahogany fitted and screwed together and simply sitting on the bulkhead amidships. The beam on Mariah has a visible belly in it and the rigging has been tightened down to make allowance over the years. There is ZERO sign of leakage through the mast step and I mean to keep it that way.
I know I have to make minor notches for mast wiring. I can prefab the beam, tie her up in a travel lift slip for a few hours, lift the mast, replace the beam and reset the mast. Has anyone done this? It's not any more complicated than this? Forgive me but I'm not used to simplification. Probably my bad habit of owning complicated American made boats for 40 years...
Aaron
Nov 11, 2016
96
Nimble Arctic Toronto
Greeting Aaron and welcome to the group. Steve Birch has a kit for strengthening the mast beam. The original is glued and screwed to the bulkhead. It should be easy to remove as the glue will have failed long ago. I recently replaced my beam with thicker wider pieces of solid oak - one on each side of the bulkhead, glued and thru-bolted with SS bolts. I cut them arch-shaped for extra strength and now have to cut the folding door to fit the new arched doorway. Should withstand a hurricane now. Trev (v2915)
Nov 11, 2016
96
