Hi Peggy,
i am at replacing the black (37gal) & grey(22gal) water tank. with the given space, it is difficult to increase the holding capacity.
Had in mind to connect both tanks in series so that if needed I could use the gray water tank as an overflow of the black water tank for increasing my holding capacity. I could connect plumbing to grey water tank to enable overboard discharge of showers and sink, when using the gray tank as an black overflow!!??
right now the gray tank is emptied via an internal sump pump. so i'm thinking of connecting both tanks to the macerator pump when using both as black, and still have an external sump with float swith for gray water mode!?
Is that doable?
any issues to consider?
what kind of valve to use to connect the black to grey tank in series, and avoid odor and blockage?
thanks "ahead " for your support
frank
Is that doable?
frank
