Grab Rail
A
Alan
I need to refinish the grab rail on our 1984 34H. Should I plan on removing the rail or an I inviting leaks to occur ?
Aug 11, 2006
1,446
Hunter H260 Traverse City
Usually unnecessary to remove
Just mask around the base with good quality plastic masking material, and refinish away!
David
Refinishing Grab Rail
Alan, I just read in Practical Sailor about a new product called hand rail masking tape. These are precut tapes that fit around the base of the hand rail that should make masking easy. As long as the rails are not in too bad a shape, you should be able to mask where the base attached to the cabin deck and finish onboard. These tape bases cost $2.98 for a roll of ten bases. You can order from the following website. www.geocities.com/baja/trails/6442 or phone at 562-596-0104
