Averaging software
Alex, Here's how the GPS determines your speed:The GPS satellite system doesn't actually track your movement across the surface of the planet; The unit on your boat determines its own location using satellite data and 'remembers' where it is. After a specified time interval, it takes another reading and compares it to the last reading; By comparing the distance between the two points and dividing that distance by the specified time interval, it can determine your speed. Now, most commercial GPS units can adjust the specified time interval- Simply stated, how frequently the unit determines its position ('Takes a fix') from the satellites. The more frequently you take a fix, the more likely you are to get an accurate 'right-now' speed; The drawback is that it will not maintain as much 'history' (i.e., unit holds 2 miles worth of track data instead of 20 miles worth). The less frequently you take a fix, the more likely it is that you are looking at your 'average' speed than your 'right-now' speed. The primary advantages to this are longer battery life (in hand-held units) and larger "back-tracking" range (unit holds 20 miles worth of data instead of 2). As for your on-board unit registering a speed while tied off at the dock, This may be due to your time interval being set a touch long- like 2 minutes- and it takes at least that long for your unit to obtain an accurate fix. After the first two fixes, your unit should realize it isn't moving (much), and register zero (or close to it).--Jon BastienH23 '2 Sheets to the Wind'Naviguessed by a handheld Garmin...
