GPS Accuracy
N
Norm Fontaine
I am a little confused as to where we are on GPS accuracy. I thought the Government was dropping the scrambling on the satelite signals so accuracy would be quite high and differentials no longer needed. Que pasa?
Jim Covey
SA is off
From what I read in Sail, Selective Availability was turned off on May 1. This means that the accuracy of the civilian GPS is now +/- 10 meters vs the old +/- 100 meters. There was an article in Sail or Cruising World a couple of months back testing the difference between GPS now and GPS+differential and a new Raytheon only system. The GPS alone could get withing a few yards of the target whereas with differential or the Raytheon system got within a few feet. IMHO GPS by itself is pretty good now. Jim Covey
Bob
Close Enough for Me
On a recent trip to SF Bay, I entered quite a few channel markers as waypoints as I passed them (within 30'-50' or so). On the way back, the GPS "spotted" them within about the same tolerance. I don't see a need for anything closer as far as navigation goes.
Tom Senator
Be Carefull the government turns
SA on every once in a while. Which will give you a lot less accurate position than you might be used to. The have done it here in Long Island Sound a few times this summer.......But most of the time it is very accurate ever since this spring.
L
Larry Dean
GPS is great
I recently sailed 130 nm putting in all the waypoints I needed in advance. The GPS was highly accurate. I tested it by putting in my home waypoint sitting in my living room. When I drove home from work the next day it tracked perfectly. In fact, It read .1 nm in my driveway and read 0 when I was back on my couch. Magellan handheld.
Rob
Garmin 12
I have a Garmin 12 - SA is definitely off, has been off for months. My receiver is routinely accurate down to 20 feet, sometimes as low as 10, and every once in a while out to 40 feet. Any way you slice it, it is a fantastic peice to technology and should be on your boat at all times. 149.oo at walmart, 129.00 at West Marine with a discount. Rob
