Mark
Recently I posted the question about running wires up to the bow.Should the wires run over the top from the elctrical panel or try to find a route under the sink. And yes there is a route. Take off the inspection plate to the starboard side of the electrical panel sort of underneath above the stove area. Then from inside the galley cupboard I pushed through a feed wire right right up in the top aft end of the cupboard. Luckily the feed wire came out against the starboard side of the hull. Of course I then taped on the electrical wires for the pump and pulled them through. I then fed the wires though the condut that carries the water pipe to the bow. Absolutly rapped that it could be done without drilling any holes and not a wire to be seen.Connected up the new 1/2" hose to the head and galley, plumbed and wired in the pump and presto. Instant water.Just one concern is that the pump company states that these little pumps are barely audable however this little fella makes quite a noise.I have however mounted the pump on a piece of flat pine and then held the pump by securing it with a strap around the water tank. So it sits on top of the water tank. Wonder if this makes it noisy. Any guidance appreciated. Perhaps I should fix it to a bulkhead??Hope this helps anyone wanting to do the same.
