Some speed thoughts
William, Save your spinnikar pole for a spinnikar and use a whisker pole for your gennie - it can be adjusted to the conditions. For downwind speed, are you easing your backstay, outhaul and cunningham? You want the fuller (deeper camber) shape in your sails. Also look at your course. Directly down-wind is generally slower than any other windanglem, especially if your main it blanketing your gennie. . Speaking of wind angles, talk to the experienced racers about "polar charts." they give a graphic representation of boat speed for each course relative to true wind. Even if you don't work one up, undestanding the implications of a "typical" polar chart can be helpful. If other h23's are racing, or even sailing in your vacinity, try sailing near them and look at their sails to see what they're doing that might help you. Consider crewing for experienced racers - you can learn a lot in a hurry. I used to have problems with a heavy weather helm upwind. Remember the adage: "when in doubt, let it out." You are probably trimmed in too tight. I try to have a small "bubble" in the main near the mast. The air flow is disturbed by the mast anyway, so no power is lost. Then trim the headsail by the tell-tails: windward tell-tails slightly lifted, leeward tell-tails streaming back. You also want to tighten your back stay adjuster and cunningham, and depending on appearent wind strength, the outhaul. Figure on going back and forth between the two as they mutually interact. Consider reading "Sail Power." It has chapters on how to trim each of your sails, and on how the sails interact.Jim Kolstoe.
