Does anyone have any knowledge of the Gori propellers? Am considering the 3 blade folding prop for my Hunter Passage. How do they compare with the others on the market?
One of the best on the market, identical efficiency in forward and reverse.I can send you copy of the brochure and name of distributor, I will check for a URL add.
The add for max-prop ishttp://max-prop.comThere is a canadian representative Jacques Harvey:jpmarine@aira.comThis prop is much better than Gori.Look at the specs.Good luck
