Hey everyone, just spent the morning on the boat tackling a few projects, the PO had installed a bracket on the transom, basic U shape with a bolt through it, filled the holes and made some holes to install the swim ladder, also installed a backing plate (¾ marine plywood) letting the six10 dry before installing the ladder.
Then I installed the deck coax fitting besides the mast step and installed the interior wire. I just need an extra coax connector for the radio end.
I worked a bit on the AC circuitry, figure I needed about an extra 6" of wire to make a good connection, so I took the old wire out and will install another/longer one next time I go to the boat.
Expecting rain for the next 2 days, so Wednesday I should have time to go finish the ladder install after work. I'll also take my belt sander with me to sand the patch I made to remove some through hulls.
