Good Mattress
rowdyroy79
I have A 1997 hUNTER 33.6. I'm looking for a better mattress for the aft cabin. The one that came with the boat seems to be flat and wore out. I would appriciate any information that would lead to a better night sleep.
Dec 2, 1999
15,184
You may also want to consider a latex mattress. It will last 20 years or more, it will not attract mold or mildew. No springs to rust and it can easily be configured to any odd shapes.
Jul 20, 2005
2,422
Whitby 55 Kemah, Tx
According to a foam expert, the foam Hunter uses is not for everyday use, but for a weekend once in a while, so if anybody has slept in it for an extended period, it is worthless. Go to a local foam store or order some from online. Most good quality foam is treated against mold and I haven't had any problem...even in winter time when the bottom of it is soaked.
The other problem is that Hunter only puts 3.5" of foam back there and it needs to be at least 7" (also from foam expert). I replaced mine with 4"of second hardest grade A foam because I didn't want to loose the headspace. That worked well for about a couple of months so then I went to walmart and got a memory foam. It was 2.5" of medium foam and 1/5" of memory foam. I put that on top of the existing foam to equal 8" total. It is now the most comfortable bed I've ever had.
Also from the expert is that don't expect even the best quality foam to last more then 4 years. Latex is supposed to last a lot longer but also costs a lot more too. Personally, I like the idea of replacing the bed every now and then; it gets rid of the bed bugs.
Jul 24, 2005
261
MacGregor Mac26D Richardson, TX; Dana Point, CA
Mattress Topper - with the right material would be OK, I think...
5" topper with high density foam - works well at home - and fairly inexpensive...
Feb 24, 2004
190
Hunter 290 Portland, Maine
I'll put a plug in for the Froli Sleep System; not cheap, but it made a world of difference for me and my wife. We went from having terrible sleep and always being up at dawn to sleeping soundly and missing the sunrise. I'll take the latter any day.
Paul
Mar 20, 2004
1,746
Ditto for us! we installed the Froli system and we sleep like babies-better than at home. In addition, the froli allows air to circulate under the mattress, preventing mildew and damp buildup
H
HARRIETS CHARIOT
Foam Replacement
I Found A Place On Line www.thefoamfactory.com (i Think).. Got Some 5" Stuff And It Is Great... Cheaper Than Anybody Around Even With Shipping But If I Remember The Shipping Was Free. They Will Even Cut It To Shape And Put Together 2 Different Densities If You Want But I Found An Electric Knife Works Fine Check It Out
Chet P Harriet's Chariot H37c #36
