Well the liner bottom actually.
My V25 has a shallow "pocket" that collects water. It is under the plywood divider panel that the seat back is snapped to. Other side of the panel is where the porta poti sits. So water collects there and if unnoticed, like over winter and spring, it will get to the plywood.
So is it a good idea to drill a hole or two in the pocket to let the water go into the bilge? Or is there a reason that this is not done? Seems to me the bilge would be where you would want the water to go. Same with the footwell under the table. Another place I would consider a hole or two.
