Not experienced but I'm working on it
I am right now in the process of installing golf cart batteries in my 27 foot Catalina - 75 vintage. Here are some issues I have dealt with:1) Amps - most of my cruises will be shorter rather than longer - I think that is true with most folks. I plan on around 100 Amps a day to run a refrigerator, chart plotter/radar/fish finder (depth sounder, lights on occasions, microwave (I figure about 20 minutes a day). In the off season, I plan to run an electric heater off of the 1000 watt inverter, I will run the heater at 900 watts for around 8 hours if the cold becomes an issue inside the boat while sleeping - I like my creaturely comforts.Number of golf cart batteries - I decided 6 batteries will give me 3 days at one hundred amps. Or, I can run that electric heater longer on weekend cruises - 2 days. My batteries are 215 amps but at 6 volts have to be wired in parallel to get 12 volts. 6 batteries will give me a total of 600 amps, but run down to 50% only, yields a 300 amp usage.Inverter - I purposely purchased a 1000 watt inverter to run those items I might want to while under way or at anchor, like the microwave. I purposely chose the smaller inverter at 1000 watts to force myself to be conscious of the items that use power to conserve energy. For example, my wife can use a hair blower set on medium power for about 5 minutes and she will be happy.We lived in a recreational trailer years ago, first a 21 foot trailer, then a 35 foot fifth wheel. The total amps we could use at the one trailer park we were at the most was 15 amps for everything. After kicking off a number of fuses we became efficient a power use - like the hair blower at half power.Boat trim - those batteries do weigh a lot, mine around 63 pounds each. I have a large space in my Catalina that was for an inboard motor, however since I have an outboard, I have lots of space available. I was going to put all 6 batteries in this location (lots of room) but decided against it for boat trim reasons. I might put two in the front under the V birth, venting the V birth, and four in the back. This will offset the greater weight in the back somewhat.Solar panels/ wind generators/ Honda Generator:I went through the solar panel and wind generator thing and decided that if I have 300 amps to play with I should be cover about 90 % of the trips I will make in the boat. If I go out for two weeks, I've decided two things a) shore power will allow me to recharge if I stay on shore power for around 24 hours; and b) a 2000 watt Honda generator should give me about 200 amps of charge if I let it run all day (hit an island and do lots of hiking to get away from the rather silent generator).Solar panels for serious recharging are expensive and slow. Wind generators are better for speed of charging but rely on the wind, which may not be there in the summer (Pacific North West) and can vibrate badly and be a bit noisy. Some serious boaters (by this I mean those who want to use a number of electrical items during there cruise) are combining the two - wind generator and solar panels.By and large, I feel I will be able to get by with 300 amps for about 4 days if I watch my usage and that seems to be the cheapest option to go. If I feel I need more power I'll bring my Honda generator (earth quake preparedness - a good excuse to get one) along with me, for that one very long cruise.PS: My boat had no power to it at all, not even shore power. So I have had some one come down to the boat and add shore power (AC) and included outlets around the boat to use heaters and fans when permanently moored (to keep the boat dry and mold free). I have all the gizmo's needed to now add my batteries, including a quality inverter and battery charger.I edited this in: I almost forgot, I have seperate battery for the electric outboard engine, and a spare battery with built in inverter in case I do something stupid and kill all the batteries - I will still be able to start the motor. Or watch a movie with this battery on my lap top. I have a small solar panel trickle charger for this portable emergency battery.Have a Happy and Safe Holiday.
